How do I connect the DJI Mavic 4 Pro to the DJI RC Pro remote controller?
How do I connect the DJI Mavic 4 Pro to the DJI RC Pro remote controller: The connection between the DJI Mavic 4 Pro and the DJI RC Pro remote controller is designed to be fast, stable, and secure thanks to the OcuSync 4.0 transmission system. In most cases, this connection is preset at the factory, so when you turn on both devices, they pair automatically. However, if for some reason the connection fails, or if you change controllers, you must perform manual pairing using a simple process in the DJI Fly app.
To pair manually, first turn on both devices and access the DJI Fly app on the remote controller. From the main interface, go to the settings menu (three-dot icon) and select the “Pair Aircraft” option. Once there, you will be prompted to press the pairing button on the drone, which is usually located near the battery or on the side compartment. Hold it down for a few seconds until the LEDs flash rapidly, indicating that it is in pairing mode.
After a few seconds, the app should confirm a successful connection. The controller will then display the live view of the drone's camera, along with the battery status, GPS signal, and other important flight parameters. If pairing fails, make sure the firmware on both devices is up to date and repeat the process. It's also important to avoid external interference during pairing, such as congested Wi-Fi networks or nearby Bluetooth devices.
A proper and stable connection is vital for drone control, especially during long-range operations or in obstructed environments. Pairing ensures that the controller has priority over other connection attempts and guarantees smooth video transmission without latency or interruptions. Familiarizing yourself with this process allows for easy controller swapping in the event of an emergency or replacement, and improves the pilot's operational readiness.
