What are the applications of Fixed-Wing Mode on the DJI Flip, and how does it work?
What are the applications of Fixed-Wing Mode on the DJI Flip, and how does it work: Fixed-Wing Mode on the DJI Flip allows the drone to fly similarly to a fixed-wing aircraft, maintaining a constant direction and speed while performing fluid, dynamic movements. This mode partially disables the automatic braking functions and prevents the drone from abruptly stopping its movement, resulting in a more immersive and cinematic flight experience. It is ideal for capturing long shots of landscapes, sporting events, or tours over large areas.
To activate Fixed-Wing Mode, the operator selects the function in the DJI Fly app and adjusts the initial speed and direction. Once activated, the drone continues flying on the set path, allowing the operator to make smooth turns and minor adjustments to maintain the desired frame. This makes it a powerful tool for projects that require continuous, stable movements.
Fixed-Wing mode is especially useful for cinematic footage that simulates the motion of an aircraft, such as a long shot over an open field or a flight through a valley. By maintaining constant direction and speed, this mode ensures smooth and visually stunning footage, eliminating the need for frequent manual corrections.
Although the mode is designed to prioritize smoothness, the DJI Flip's stabilization and obstacle avoidance systems remain active to ensure safety during flight. This ensures the drone can operate reliably even in challenging environments, making Fixed-Wing mode a versatile option for both recreational users and professionals seeking high-quality cinematic results.
